Hello!
How can I correctly implement in Robot the movement joint like this one?
Thanks a lot!
Solved by Artur.Kosakowski. Go to Solution.
Releases at the edges of the panels.
If you want to model friction effect, then non linear release but you will go for a non linear analysis as well.
Don't forget to turn on dsc algorithm in the job preference.
Thanks for the response,
I want tio take into account in the calculation the eccentricity in tne wall and in the beam.. How can I do it?
Regards
Denis
