Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Moment in long direction is greater than moment in short direction ?!
8 REPLIES 8
Message 1 of 9
922 Views, 8 Replies
Hi everybody
can anyone tell me why the moment in the long direction is greater than the moment in the short direction ?
it should be the opposit !!
sloid slab with 40X50 edge beams
8 REPLIES 8
Message 2 of 9
the robot file
Message 3 of 9
Artur.Kosakowski
You need to be careful in matching the selected result type with the direction on which you project it.
Artur Kosakowski
Message 4 of 9
in reply to: Artur.Kosakowski
Thanks arther
recpect to what you said , but the same result apper
in structural behavior it is known that the force goes in the shortest direction
and by looking at the picture below , it shows a coefficient multiples by the moment depending on the length to width ratio
in my case let us say that the edges is pinned and the ratio is (5/10 =0.5) , then the short direction is multiple by 0.95 and the long direction by 0.05
which means the moment in the short dirction should be much larger thn in the long direction .
Message 5 of 9
Rafacascudo
I think this table is for fully supported slab on its edges.Results get better if you model this in Robot
fully supported slab(pinned
Rafael Medeiros
Message 6 of 9
in reply to: Rafacascudo
WOW , i am amazed
nice result Smiley Happy
but my slab is fully support by beams !
this is realy strang
Message 7 of 9
It looks as if your longitudinal beams were not sufficiently stiff - that cause resultant moment distribution in the opposite direction
Message 8 of 9
Artur.Kosakowski
Opps - I'm sorry I entirely misunderstood the question Smiley Embarassed Luckily
Artur Kosakowski
Message 9 of 9
Ok , now i got it
it is all about the stiffness of the beams supporting the slab
thanks a lot artur , god bless you Smiley Wink
