Tony,
Have fun (these code copies hinges from robot kernel to Robot but it will give you idea how to access data):
Public Sub NonLinFunctionsHandle(ByVal r As RobotOM.RobotApplication, ByVal k As KernelOM.RobotKernel) FormMain.ProgressBarInit(1, "nonlinear functions") FormMain.log.AddComment("definition of nonlinear functions") Dim KnlL As KernelOM.RobotNonlinearLink Dim nlLP As RobotOM.IRobotNonlinearLinkParams Dim nlL As RobotOM.RobotNonlinearLink Dim i As Integer Dim j As Integer Dim q As Integer Dim f_ As Integer Dim t_ As Integer For i = 1 To r.Project.Structure.Nodes.NonlinearLinks.Count nlL = r.Project.Structure.Nodes.NonlinearLinks.Get(i) KnlL = k.Structure.Nodes.NonlinearLinks.Create(nlL.Name) KnlL.ModelType = nlL.ModelType If nlL.Symetry Then f_ = RobotOM.IRobotNonlinearLinkSemiAxisType.I_NLSAT_ANY t_ = RobotOM.IRobotNonlinearLinkSemiAxisType.I_NLSAT_ANY Else f_ = RobotOM.IRobotNonlinearLinkSemiAxisType.I_NLSAT_POSITIVE t_ = RobotOM.IRobotNonlinearLinkSemiAxisType.I_NLSAT_NEGATIVE End If For j = f_ To t_ nlLP = nlL.GetParams(j) KnlL.SetCurveType(nlLP.CurveType, j) If nlLP.CurveType = RobotOM.IRobotNonlinearLinkCurveType.I_NLCT_B_LINEAR Then Dim KnnLP As KernelOM.RobotNonlinearLinkParamsBLinear Dim nllP_ As RobotOM.RobotNonlinearLinkParamsBLinear KnnLP = KnlL.GetParams(j) nllP_ = nlL.GetParams(j) KnnLP.K1 = nllP_.K1 KnnLP.K2 = nllP_.K2 KnnLP.d1 = nllP_.d1 KnlL.SetParams(KnnLP) ElseIf nlLP.CurveType = RobotOM.IRobotNonlinearLinkCurveType.I_NLCT_CUSTOM Then Dim KnnLP As KernelOM.RobotNonlinearLinkParamsCustom Dim nllP_ As RobotOM.RobotNonlinearLinkParamsCustom KnnLP = KnlL.GetParams(j) nllP_ = nlL.GetParams(j) For q = 1 To nllP_.Count Dim seg As RobotOM.RobotNonlinearLinkParamsCustomSegment Dim Kseg As KernelOM.RobotNonlinearLinkParamsCustomSegment seg = nllP_.Get(q) Kseg = KnnLP.[New]() Kseg.Constant = seg.Constant Kseg.Expression = seg.Expression Kseg.OriginPoint = seg.OriginPoint KnnLP.Set(q, Kseg) Next KnlL.SetParams(KnnLP) ElseIf nlLP.CurveType = RobotOM.IRobotNonlinearLinkCurveType.I_NLCT_GAP_HOOK Then Dim KnnLP As KernelOM.RobotNonlinearLinkParamsGapHook Dim nllP_ As RobotOM.RobotNonlinearLinkParamsGapHook KnnLP = KnlL.GetParams(j) nllP_ = nlL.GetParams(j) KnnLP.K = nllP_.K KnnLP.D = nllP_.D KnlL.SetParams(KnnLP) ElseIf nlLP.CurveType = RobotOM.IRobotNonlinearLinkCurveType.I_NLCT_LINEAR Then Dim KnnLP As KernelOM.RobotNonlinearLinkParamsLinear Dim nllP_ As RobotOM.RobotNonlinearLinkParamsLinear KnnLP = KnlL.GetParams(j) nllP_ = nlL.GetParams(j) KnnLP.K = nllP_.K KnlL.SetParams(KnnLP) ElseIf nlLP.CurveType = RobotOM.IRobotNonlinearLinkCurveType.I_NLCT_PARABOLIC Then Dim KnnLP As KernelOM.RobotNonlinearLinkParamsParabolic Dim nllP_ As RobotOM.RobotNonlinearLinkParamsParabolic KnnLP = KnlL.GetParams(j) nllP_ = nlL.GetParams(j) KnnLP.Dlim = nllP_.Dlim KnnLP.Dmax = nllP_.Dmax KnnLP.Flim = nllP_.Flim KnnLP.K = nllP_.K KnlL.SetParams(KnnLP) ElseIf nlLP.CurveType = RobotOM.IRobotNonlinearLinkCurveType.I_NLCT_PARABOLIC_EC2 Then '? Dim KnnLP As KernelOM.RobotNonlinearLinkParamsParabolic Dim nllP_ As RobotOM.RobotNonlinearLinkParamsParabolic KnnLP = KnlL.GetParams(j) nllP_ = nlL.GetParams(j) KnnLP.Dlim = nllP_.Dlim KnnLP.Dmax = nllP_.Dmax KnnLP.Flim = nllP_.Flim KnnLP.K = nllP_.K KnlL.SetParams(KnnLP) ElseIf nlLP.CurveType = RobotOM.IRobotNonlinearLinkCurveType.I_NLCT_PERFECTLY_PLASTIC Then Dim KnnLP As KernelOM.RobotNonlinearLinkParamsPlastic Dim nllP_ As RobotOM.RobotNonlinearLinkParamsPlastic KnnLP = KnlL.GetParams(j) nllP_ = nlL.GetParams(j) KnnLP.Dlim = nllP_.Dlim KnnLP.Flim = nllP_.Flim KnnLP.W = nllP_.W KnnLP.K = nllP_.K KnlL.SetParams(KnnLP) ElseIf nlLP.CurveType = RobotOM.IRobotNonlinearLinkCurveType.I_NLCT_PLASTIC_WITH_HARDENING Then Dim KnnLP As KernelOM.RobotNonlinearLinkParamsPlasticHardening Dim nllP_ As RobotOM.RobotNonlinearLinkParamsPlasticHardening KnnLP = KnlL.GetParams(j) nllP_ = nlL.GetParams(j) KnnLP.Dlim = nllP_.Dlim KnnLP.Flim = nllP_.Flim KnnLP.W = nllP_.W KnnLP.K0 = nllP_.K0 KnnLP.K1 = nllP_.K1 KnlL.SetParams(KnnLP) Else 'not handled End If Next Next 'non-linear hinge functions Dim nlHP As RobotOM.RobotNonlinearHingeModelAxisParams Dim KnlHP As KernelOM.RobotNonlinearHingeModelAxisParams Dim KnlHM As KernelOM.RobotNonlinearHingeModelPoints Dim nlHM As RobotOM.RobotNonlinearHingeModelPoints Dim nlH As RobotOM.RobotNonlinearHingeModel Dim KnlH As KernelOM.RobotNonlinearHingeModel For i = 1 To r.Project.Structure.Bars.NonlinearHingeModels.Count nlH = r.Project.Structure.Bars.NonlinearHingeModels.Get(i) KnlH = k.Structure.Bars.NonlinearHingeModels.Create(nlH.Name) If nlH.Symetry Then f_ = RobotOM.IRobotNonlinearLinkSemiAxisType.I_NLSAT_ANY t_ = RobotOM.IRobotNonlinearLinkSemiAxisType.I_NLSAT_ANY Else f_ = RobotOM.IRobotNonlinearLinkSemiAxisType.I_NLSAT_POSITIVE t_ = RobotOM.IRobotNonlinearLinkSemiAxisType.I_NLSAT_NEGATIVE End If KnlH.ModelType = nlH.ModelType KnlH.UnloadingMethod = nlH.UnloadingMethod If KnlH.UnloadingMethod = KernelOM.IRobotNonlinearHingeModelUnloadingType.I_NHMUT_MIXED Then KnlH.MixedUnloadingValue = nlH.MixedUnloadingValue End If KnlH.LimitCoordX = nlH.LimitCoordX If KnlH.LimitCoordX Then KnlH.LimitCoordXValue = nlH.LimitCoordXValue End If KnlH.LimitCoordY = nlH.LimitCoordY If KnlH.LimitCoordY Then KnlH.LimitCoordYValue = nlH.LimitCoordYValue End If For j = f_ To t_ nlHP = nlH.GetAxisParams(j) KnlHP = KnlH.GetAxisParams(j) KnlHP.ImmediateOccupancy = nlHP.ImmediateOccupancy KnlHP.LifeSafety = nlHP.LifeSafety KnlHP.StructuralStability = nlHP.StructuralStability KnlH.SetAxisParams(j, KnlHP) KnlHM = KnlH.GetPoints(j) nlHM = nlH.GetPoints(j) For q = 1 To KnlHM.Count Dim Kgp2d As KernelOM.RobotGeoPoint2D Kgp2d = k.CmpntFactory.Create(KernelOM.IRobotComponentType.I_CT_GEO_POINT_2D) Kgp2d.Set(nlHM.Get(j).X, nlHM.Get(j).Y) KnlHM.Set(q, Kgp2d) Next Next Next FormMain.ProgressBarNextStep() End Sub
'non-linear hinge functions Dim nlHP As RobotOM.RobotNonlinearHingeModelAxisParams Dim KnlHP As KernelOM.RobotNonlinearHingeModelAxisParams Dim KnlHM As KernelOM.RobotNonlinearHingeModelPoints Dim nlHM As RobotOM.RobotNonlinearHingeModelPoints Dim nlH As RobotOM.RobotNonlinearHingeModel Dim KnlH As KernelOM.RobotNonlinearHingeModel For i = 1 To r.Project.Structure.Bars.NonlinearHingeModels.Count nlH = r.Project.Structure.Bars.NonlinearHingeModels.Get(i) KnlH = k.Structure.Bars.NonlinearHingeModels.Create(nlH.Name) If nlH.Symetry Then f_ = RobotOM.IRobotNonlinearLinkSemiAxisType.I_NLSAT_ANY t_ = RobotOM.IRobotNonlinearLinkSemiAxisType.I_NLSAT_ANY Else f_ = RobotOM.IRobotNonlinearLinkSemiAxisType.I_NLSAT_POSITIVE t_ = RobotOM.IRobotNonlinearLinkSemiAxisType.I_NLSAT_NEGATIVE End If KnlH.ModelType = nlH.ModelType KnlH.UnloadingMethod = nlH.UnloadingMethod If KnlH.UnloadingMethod = KernelOM.IRobotNonlinearHingeModelUnloadingType.I_NHMUT_MIXED Then KnlH.MixedUnloadingValue = nlH.MixedUnloadingValue End If KnlH.LimitCoordX = nlH.LimitCoordX If KnlH.LimitCoordX Then KnlH.LimitCoordXValue = nlH.LimitCoordXValue End If KnlH.LimitCoordY = nlH.LimitCoordY If KnlH.LimitCoordY Then KnlH.LimitCoordYValue = nlH.LimitCoordYValue End If For j = f_ To t_ nlHP = nlH.GetAxisParams(j) KnlHP = KnlH.GetAxisParams(j) KnlHP.ImmediateOccupancy = nlHP.ImmediateOccupancy KnlHP.LifeSafety = nlHP.LifeSafety KnlHP.StructuralStability = nlHP.StructuralStability KnlH.SetAxisParams(j, KnlHP) KnlHM = KnlH.GetPoints(j) nlHM = nlH.GetPoints(j) For q = 1 To KnlHM.Count Dim Kgp2d As KernelOM.RobotGeoPoint2D Kgp2d = k.CmpntFactory.Create(KernelOM.IRobotComponentType.I_CT_GEO_POINT_2D) Kgp2d.Set(nlHM.Get(j).X, nlHM.Get(j).Y) KnlHM.Set(q, Kgp2d) Next Next Next Private Function NLHinge(ByRef Klab As KernelOM.RobotLabel, ByVal lab As RobotOM.RobotLabel) As KernelOM.RobotLabel 'todo - nl function def Dim KnlhData As KernelOM.RobotNonlinearHingeData Dim nlhData As RobotOM.RobotNonlinearHingeData KnlhData = Klab.Data nlhData = lab.Data KnlhData.NormalStress = nlhData.NormalStress If nlhData.IsActive(RobotOM.IRobotNonlinearHingeComponentType.I_NHCT_FX) Then KnlhData.SetModel(KernelOM.IRobotNonlinearHingeComponentType.I_NHCT_FX, nlhData.GetModel(RobotOM.IRobotNonlinearHingeComponentType.I_NHCT_FX)) End If If nlhData.IsActive(RobotOM.IRobotNonlinearHingeComponentType.I_NHCT_FY) Then KnlhData.SetModel(KernelOM.IRobotNonlinearHingeComponentType.I_NHCT_FY, nlhData.GetModel(RobotOM.IRobotNonlinearHingeComponentType.I_NHCT_FY)) End If If nlhData.IsActive(RobotOM.IRobotNonlinearHingeComponentType.I_NHCT_FZ) Then KnlhData.SetModel(KernelOM.IRobotNonlinearHingeComponentType.I_NHCT_FZ, nlhData.GetModel(RobotOM.IRobotNonlinearHingeComponentType.I_NHCT_FZ)) End If If nlhData.IsActive(RobotOM.IRobotNonlinearHingeComponentType.I_NHCT_MX) Then KnlhData.SetModel(KernelOM.IRobotNonlinearHingeComponentType.I_NHCT_MX, nlhData.GetModel(RobotOM.IRobotNonlinearHingeComponentType.I_NHCT_MX)) End If If nlhData.IsActive(RobotOM.IRobotNonlinearHingeComponentType.I_NHCT_MY) Then KnlhData.SetModel(KernelOM.IRobotNonlinearHingeComponentType.I_NHCT_MY, nlhData.GetModel(RobotOM.IRobotNonlinearHingeComponentType.I_NHCT_MY)) End If If nlhData.IsActive(RobotOM.IRobotNonlinearHingeComponentType.I_NHCT_MZ) Then KnlhData.SetModel(KernelOM.IRobotNonlinearHingeComponentType.I_NHCT_MZ, nlhData.GetModel(RobotOM.IRobotNonlinearHingeComponentType.I_NHCT_MZ)) End If If nlhData.IsActive(RobotOM.IRobotNonlinearHingeComponentType.I_NHCT_SX) Then KnlhData.SetModel(KernelOM.IRobotNonlinearHingeComponentType.I_NHCT_SX, nlhData.GetModel(RobotOM.IRobotNonlinearHingeComponentType.I_NHCT_SX)) End If NLHinge = Klab End Function
Nonlinear Support example
Private Function Support(ByRef Klab As KernelOM.RobotLabel, ByVal lab As RobotOM.RobotLabel) As KernelOM.RobotLabel Dim supData As RobotOM.RobotNodeSupportData Dim KsupData As KernelOM.RobotNodeSupportData KsupData = Klab.Data supData = lab.Data KsupData.UX = supData.UX KsupData.UY = supData.UY KsupData.UZ = supData.UZ KsupData.RX = supData.RX KsupData.RY = supData.RY KsupData.RZ = supData.RZ KsupData.HX = supData.HX KsupData.HY = supData.HY KsupData.HZ = supData.HZ KsupData.KX = supData.KX KsupData.KY = supData.KY KsupData.KZ = supData.KZ KsupData.AX = supData.AX KsupData.AY = supData.AY KsupData.AZ = supData.AZ KsupData.BX = supData.BX KsupData.BY = supData.BY KsupData.BZ = supData.BZ KsupData.GlobalCoordSystem = supData.GlobalCoordSystem KsupData.Alpha = supData.Alpha KsupData.Beta = supData.Beta KsupData.Gamma = supData.Gamma KsupData.Advanced.B = supData.Advanced.B KsupData.Advanced.D = supData.Advanced.D KsupData.Advanced.H = supData.Advanced.H KsupData.Advanced.Type = supData.Advanced.Type If supData.Advanced.IsEquivalentElasticity Then KsupData.Advanced.EquivalentElasticity.E = supData.Advanced.EquivalentElasticity.E KsupData.Advanced.EquivalentElasticity.E = supData.Advanced.EquivalentElasticity.PoissonRatio End If KsupData.ElasticLinear = supData.ElasticLinear KsupData.ElasticSurface = supData.ElasticSurface KsupData.SetOneDir(KernelOM.IRobotNodeSupportFixingDirection.I_NSFD_UX, supData.GetOneDir(RobotOM.IRobotNodeSupportFixingDirection.I_NSFD_UX)) KsupData.SetOneDir(KernelOM.IRobotNodeSupportFixingDirection.I_NSFD_UY, supData.GetOneDir(RobotOM.IRobotNodeSupportFixingDirection.I_NSFD_UY)) KsupData.SetOneDir(KernelOM.IRobotNodeSupportFixingDirection.I_NSFD_UZ, supData.GetOneDir(RobotOM.IRobotNodeSupportFixingDirection.I_NSFD_UZ)) KsupData.SetOneDir(KernelOM.IRobotNodeSupportFixingDirection.I_NSFD_RX, supData.GetOneDir(RobotOM.IRobotNodeSupportFixingDirection.I_NSFD_RX)) KsupData.SetOneDir(KernelOM.IRobotNodeSupportFixingDirection.I_NSFD_RY, supData.GetOneDir(RobotOM.IRobotNodeSupportFixingDirection.I_NSFD_RY)) KsupData.SetOneDir(KernelOM.IRobotNodeSupportFixingDirection.I_NSFD_RZ, supData.GetOneDir(RobotOM.IRobotNodeSupportFixingDirection.I_NSFD_RZ)) If supData.NonlinearModel.IsDefined(RobotOM.IRobotDegreeOfFreedom.I_DOF_UX) Then KsupData.NonlinearModel.Set(KernelOM.IRobotDegreeOfFreedom.I_DOF_UX, supData.NonlinearModel.Get(RobotOM.IRobotDegreeOfFreedom.I_DOF_UX)) End If If supData.NonlinearModel.IsDefined(RobotOM.IRobotDegreeOfFreedom.I_DOF_UY) Then KsupData.NonlinearModel.Set(KernelOM.IRobotDegreeOfFreedom.I_DOF_UY, supData.NonlinearModel.Get(RobotOM.IRobotDegreeOfFreedom.I_DOF_UY)) End If If supData.NonlinearModel.IsDefined(RobotOM.IRobotDegreeOfFreedom.I_DOF_UZ) Then KsupData.NonlinearModel.Set(KernelOM.IRobotDegreeOfFreedom.I_DOF_UZ, supData.NonlinearModel.Get(RobotOM.IRobotDegreeOfFreedom.I_DOF_UZ)) End If If supData.NonlinearModel.IsDefined(RobotOM.IRobotDegreeOfFreedom.I_DOF_RX) Then KsupData.NonlinearModel.Set(KernelOM.IRobotDegreeOfFreedom.I_DOF_RX, supData.NonlinearModel.Get(RobotOM.IRobotDegreeOfFreedom.I_DOF_RX)) End If If supData.NonlinearModel.IsDefined(RobotOM.IRobotDegreeOfFreedom.I_DOF_RY) Then KsupData.NonlinearModel.Set(KernelOM.IRobotDegreeOfFreedom.I_DOF_RY, supData.NonlinearModel.Get(RobotOM.IRobotDegreeOfFreedom.I_DOF_RY)) End If If supData.NonlinearModel.IsDefined(RobotOM.IRobotDegreeOfFreedom.I_DOF_RZ) Then KsupData.NonlinearModel.Set(KernelOM.IRobotDegreeOfFreedom.I_DOF_RZ, supData.NonlinearModel.Get(RobotOM.IRobotDegreeOfFreedom.I_DOF_RZ)) End If Support = Klab End Function
Nonlinear Release example
Private Function Release(ByRef Klab As KernelOM.RobotLabel, ByVal lab As RobotOM.RobotLabel) As KernelOM.RobotLabel Dim KrelData As KernelOM.RobotBarReleaseData Dim relData As RobotOM.RobotBarReleaseData KrelData = Klab.Data relData = lab.Data KrelData.StartNode.AX = relData.StartNode.AX KrelData.StartNode.AY = relData.StartNode.AY KrelData.StartNode.AZ = relData.StartNode.AZ KrelData.StartNode.BX = relData.StartNode.BX KrelData.StartNode.BY = relData.StartNode.BY KrelData.StartNode.BZ = relData.StartNode.BZ KrelData.StartNode.HX = relData.StartNode.HX KrelData.StartNode.HY = relData.StartNode.HY KrelData.StartNode.HZ = relData.StartNode.HZ KrelData.StartNode.KX = relData.StartNode.KX KrelData.StartNode.KY = relData.StartNode.KY KrelData.StartNode.KZ = relData.StartNode.KZ KrelData.StartNode.RX = relData.StartNode.RX KrelData.StartNode.RY = relData.StartNode.RY KrelData.StartNode.RZ = relData.StartNode.RZ KrelData.StartNode.UX = relData.StartNode.UX KrelData.StartNode.UY = relData.StartNode.UY KrelData.StartNode.UZ = relData.StartNode.UZ KrelData.EndNode.AX = relData.EndNode.AX KrelData.EndNode.AY = relData.EndNode.AY KrelData.EndNode.AZ = relData.EndNode.AZ KrelData.EndNode.BX = relData.EndNode.BX KrelData.EndNode.BY = relData.EndNode.BY KrelData.EndNode.BZ = relData.EndNode.BZ KrelData.EndNode.HX = relData.EndNode.HX KrelData.EndNode.HY = relData.EndNode.HY KrelData.EndNode.HZ = relData.EndNode.HZ KrelData.EndNode.KX = relData.EndNode.KX KrelData.EndNode.KY = relData.EndNode.KY KrelData.EndNode.KZ = relData.EndNode.KZ KrelData.EndNode.RX = relData.EndNode.RX KrelData.EndNode.RY = relData.EndNode.RY KrelData.EndNode.RZ = relData.EndNode.RZ KrelData.EndNode.UX = relData.EndNode.UX KrelData.EndNode.UY = relData.EndNode.UY KrelData.EndNode.UZ = relData.EndNode.UZ If relData.StartNode.NonlinearModel.IsDefined(RobotOM.IRobotDegreeOfFreedom.I_DOF_RX) Then KrelData.StartNode.NonlinearModel.Set(KernelOM.IRobotDegreeOfFreedom.I_DOF_RX, relData.StartNode.NonlinearModel.Get(RobotOM.IRobotDegreeOfFreedom.I_DOF_RX)) End If If relData.StartNode.NonlinearModel.IsDefined(RobotOM.IRobotDegreeOfFreedom.I_DOF_RY) Then KrelData.StartNode.NonlinearModel.Set(KernelOM.IRobotDegreeOfFreedom.I_DOF_RY, relData.StartNode.NonlinearModel.Get(RobotOM.IRobotDegreeOfFreedom.I_DOF_RY)) End If If relData.StartNode.NonlinearModel.IsDefined(RobotOM.IRobotDegreeOfFreedom.I_DOF_RZ) Then KrelData.StartNode.NonlinearModel.Set(KernelOM.IRobotDegreeOfFreedom.I_DOF_RZ, relData.StartNode.NonlinearModel.Get(RobotOM.IRobotDegreeOfFreedom.I_DOF_RZ)) End If If relData.StartNode.NonlinearModel.IsDefined(RobotOM.IRobotDegreeOfFreedom.I_DOF_UX) Then KrelData.StartNode.NonlinearModel.Set(KernelOM.IRobotDegreeOfFreedom.I_DOF_UX, relData.StartNode.NonlinearModel.Get(RobotOM.IRobotDegreeOfFreedom.I_DOF_UX)) End If If relData.StartNode.NonlinearModel.IsDefined(RobotOM.IRobotDegreeOfFreedom.I_DOF_UY) Then KrelData.StartNode.NonlinearModel.Set(KernelOM.IRobotDegreeOfFreedom.I_DOF_UY, relData.StartNode.NonlinearModel.Get(RobotOM.IRobotDegreeOfFreedom.I_DOF_UY)) End If If relData.StartNode.NonlinearModel.IsDefined(RobotOM.IRobotDegreeOfFreedom.I_DOF_UZ) Then KrelData.StartNode.NonlinearModel.Set(KernelOM.IRobotDegreeOfFreedom.I_DOF_UZ, relData.StartNode.NonlinearModel.Get(RobotOM.IRobotDegreeOfFreedom.I_DOF_UZ)) End If If relData.EndNode.NonlinearModel.IsDefined(RobotOM.IRobotDegreeOfFreedom.I_DOF_RX) Then KrelData.EndNode.NonlinearModel.Set(KernelOM.IRobotDegreeOfFreedom.I_DOF_RX, relData.EndNode.NonlinearModel.Get(RobotOM.IRobotDegreeOfFreedom.I_DOF_RX)) End If If relData.EndNode.NonlinearModel.IsDefined(RobotOM.IRobotDegreeOfFreedom.I_DOF_RY) Then KrelData.EndNode.NonlinearModel.Set(KernelOM.IRobotDegreeOfFreedom.I_DOF_RY, relData.EndNode.NonlinearModel.Get(RobotOM.IRobotDegreeOfFreedom.I_DOF_RY)) End If If relData.EndNode.NonlinearModel.IsDefined(RobotOM.IRobotDegreeOfFreedom.I_DOF_RZ) Then KrelData.EndNode.NonlinearModel.Set(KernelOM.IRobotDegreeOfFreedom.I_DOF_RZ, relData.EndNode.NonlinearModel.Get(RobotOM.IRobotDegreeOfFreedom.I_DOF_RZ)) End If If relData.EndNode.NonlinearModel.IsDefined(RobotOM.IRobotDegreeOfFreedom.I_DOF_UX) Then KrelData.EndNode.NonlinearModel.Set(KernelOM.IRobotDegreeOfFreedom.I_DOF_UX, relData.EndNode.NonlinearModel.Get(RobotOM.IRobotDegreeOfFreedom.I_DOF_UX)) End If If relData.EndNode.NonlinearModel.IsDefined(RobotOM.IRobotDegreeOfFreedom.I_DOF_UY) Then KrelData.EndNode.NonlinearModel.Set(KernelOM.IRobotDegreeOfFreedom.I_DOF_UY, relData.EndNode.NonlinearModel.Get(RobotOM.IRobotDegreeOfFreedom.I_DOF_UY)) End If If relData.EndNode.NonlinearModel.IsDefined(RobotOM.IRobotDegreeOfFreedom.I_DOF_UZ) Then KrelData.EndNode.NonlinearModel.Set(KernelOM.IRobotDegreeOfFreedom.I_DOF_UZ, relData.EndNode.NonlinearModel.Get(RobotOM.IRobotDegreeOfFreedom.I_DOF_UZ)) End If Release = Klab End Function
I saw your code and at last made a function that enters the release functions into robot.
But they get jerky and Robot doesen´t calculate correctly. Tryed iterating more values but still wrong values at calculate.
Any ideas on what I am missing?
Dim segments As Integer
Dim segment(15, 2) As Double
Dim i As Integer
Dim n As Integer
Dim vinkel(15) As Double
Dim värdet(15) As Double
Dim KnlL As RobotOM.RobotNonlinearLink
Dim KnnLP As RobotOM.RobotNonlinearLinkParamsCustom
Dim Kseg As RobotOM.RobotNonlinearLinkParamsCustomSegment
Const I_NLCT_CUSTOM = 8
robapp.Project.Structure.Nodes.NonlinearLinks.Remove(robapp.Project.Structure.Nodes.NonlinearLinks.Find("AHMyD"))
KnlL = robapp.Project.Structure.Nodes.NonlinearLinks.Create("AHMyD")
KnlL.SetCurveType(I_NLCT_CUSTOM, RobotOM.IRobotNonlinearLinkSemiAxisType.I_NLSAT_ANY)
KnlL.ModelType = RobotOM.IRobotNonlinearLinkModelType.I_NLMT_MOMENT_ROTATION
KnnLP = KnlL.GetParams(RobotOM.IRobotNonlinearLinkSemiAxisType.I_NLSAT_ANY)
n = 0
segments = 5
värdet(1) = 0
vinkel(1) = 0.0257
värdet(2) = 0.375
vinkel(2) = 0.0463
värdet(3) = 0.465
vinkel(3) = 0.0515
värdet(4) = 0.555
vinkel(4) = 0.0582
värdet(5) = 0.629
vinkel(5) = 0.0654
For i = 1 To segments - 1
For j = 1 To 1
Kseg.Expression = Str$((värdet(i) + (värdet(i + 1) - värdet(i)) / 10 * j) * 1000)
Kseg.OriginPoint = (vinkel(i) + (vinkel(i + 1) - vinkel(i)) / 10 * j)
n = n + 1
KnnLP.Set(n, Kseg)
KnlL.SetParams(KnnLP, IRobotNonlinearLinkSemiAxisType.I_NLSAT_ANY)
Next
Next
KnlL = Nothing
KnnLP = Nothing
Kseg = Nothing
And this is what i get 😞
I am expecting a curve that robot uses. like when i input the values manually and not from api
Hi All
I need to create a nonlinear release in a excel sheet to simulate headed studs in a composite beam but I'm not succeeding in...
I am not an advance programmer, and these codes are a little bit confused for me.
I tried to copie yours codes into my excel but they didn't work. When i 'm setting the curve type the line code stays red and it shows a worning saying :"Expected :="
What i'm doing wrong?
Hi All Again,
I've been trying some codes and the best was this one:
Dim RLabel As RobotLabel
Dim relData As RobotBarReleaseData
Dim EndData As RobotBarEndReleaseData
Dim KnlL As RobotNonlinearLink
Dim KnnLP As RobotNonlinearLinkParamsBLinear
Set KnlL = str.Nodes.NonlinearLinks.Create("ConectorBiLinear")
Const I_NLCT_B_LINEAR = 2
KnlL.ModelType = IRobotNonlinearLinkModelType.I_NLMT_FORCE_DISPLACEMENT
KnlL.SetCurveType (I_NLCT_B_LINEAR)
Set KnnLP = KnlL.GetParams(I_NLSAT_POSITIVE)
KnnLP.d1 = 1
KnnLP.K1 = 54000
KnnLP.K2 = 10000
Set RLabel = str.labels.Create(I_LT_BAR_RELEASE, "CONECTOR")
Set relData = RLabel.Data
' Set EndData = relData.StartNode
' EndData.UX = I_BERV_NONLINEAR
' EndData.UX = I_BERV_STD
Set EndData = relData.EndNode
str.labels.Store RLabel
str.Bars.SetLabel selectionBars, I_LT_BAR_RELEASE, "CONECTOR"
By the way, when i try to set the parameters d1 K1 and K2, the code doesn't assume that.
1. Try set params after definition
KnlL.SetParams KnnLP
and
2. Assign nonlinear model to desired direction
EndData.NonlinearModel.Set I_DOF_UX, "ConectorBiLinear"
fuul code:
Dim robapp As RobotApplication
Set robapp = New RobotApplication
Set KnlL = robapp.Project.Structure.Nodes.NonlinearLinks.Create("ConectorBiLinear")
KnnLP.d1 = 1
KnnLP.K1 = 54000
KnnLP.K2 = 10000
Set RLabel = robapp.Project.Structure.Labels.Create(I_LT_BAR_RELEASE, "CONECTOR")
robapp.Project.Structure.Labels.Store RLabel
Try without brackets
