Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Modifying Section thickness
3 REPLIES 3
345 Views, 3 Replies
I want to be able to use a 4x4x.5625 HSSQ section but the thickness for a 4x4 section only goes up to .5". Is it possible to modify the standard section shapes to create one with a greater thickness? If that is not possible is there a way to create a HSS tube with the dimensions i would need? I know that i can create a square tube with those dimensions but i can't find one that has the filleted edges similar to the HSS.
3 REPLIES 3
Artur.Kosakowski
Try to use the Section Builder module of the program where you can define an arbitrary shape of a profile, calculate its properties and save it in the user section database.
Artur Kosakowski
in reply to: Artur.Kosakowski
Where can I find the section builder module in the program?
Romanich
Hi, you have several ways to find it:
1.
2.
3.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
