I want to be able to use a 4x4x.5625 HSSQ section but the thickness for a 4x4 section only goes up to .5". Is it possible to modify the standard section shapes to create one with a greater thickness? If that is not possible is there a way to create a HSS tube with the dimensions i would need? I know that i can create a square tube with those dimensions but i can't find one that has the filleted edges similar to the HSS.
Try to use the Section Builder module of the program where you can define an arbitrary shape of a profile, calculate its properties and save it in the user section database.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Hi, you have several ways to find it:
1.
2.
3.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
