Discussion Groups
Robot Structural Analysis
Valued Contributor
pevelor
Accepted Solution
Modify rebar database
298 Views, 7 Replies
02-17-2013 10:46 PM
Hi
I added an question to the following thread:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Custom-rebar-database/td-p/3556398
The thread was marked as solved before I added my question so I am wondering it might be overlooked.
Please take a look.
Thanks in advance.
Peder
Please use plain text.
Valued Contributor
pevelor
Re: Custom rebar database
02-15-2013 04:39 AM in reply to: pevelor
Hi
I have done the above and I am able to save and continue as Patrick did.
However, I can't figure out how to get my new rebars to display in the reinforcement type box.
What should I do differently?
Product Support
Artur.Kosakowski
02-18-2013 02:36 AM in reply to: pevelor
Try to copy the edited database to the C:\ProgramData\Autodesk\Structural\Common Data\2013\Data\Reinf
Artur Kosakowski
Valued Contributor
pevelor
02-18-2013 03:22 AM in reply to: Artur.Kosakowski
I had actually done that. I repeated the whole process and restarted my computer which worked.
Distinguished Contributor
duchoabn
04-06-2014 10:09 AM in reply to: pevelor
dear all
please explain for me are columns in the rebar database, in image below
thank all
Product Support
Artur.Kosakowski
04-07-2014 05:53 AM in reply to: duchoabn
Have you tried to look at the description tab of the table you opened? :smileyhappy:
Artur Kosakowski
duchoabn
04-07-2014 06:44 AM in reply to: duchoabn
Dear Pro
I edit rebar database from bar_SNIP 2.03.01-84. Then I want to edit it to my database.
Please explain for me formual of : Hoolen90, Hooklen135, Hooklen 180, StirrupBendFormerDiam, HookBendFormerDiam, BarBendFormerDiam, PlainBar
What does this means?
Thank pro so much
Product Support
Artur.Kosakowski
04-07-2014 06:51 AM in reply to: duchoabn
Artur Kosakowski
