Hi
I added an question to the following thread:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Custom-rebar-database/td-p/3556398
The thread was marked as solved before I added my question so I am wondering it might be overlooked.
Please take a look.
Thanks in advance.
Peder
Solved by pevelor. Go to Solution.
Solved by Artur.Kosakowski. Go to Solution.
Hi
I have done the above and I am able to save and continue as Patrick did.
However, I can't figure out how to get my new rebars to display in the reinforcement type box.
What should I do differently?
Try to copy the edited database to the C:\ProgramData\Autodesk\Structural\Common Data\2013\Data\Reinf
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
I had actually done that. I repeated the whole process and restarted my computer which worked.
Have you tried to look at the description tab of the table you opened?
Dear Pro
I edit rebar database from bar_SNIP 2.03.01-84. Then I want to edit it to my database.
Please explain for me formual of : Hoolen90, Hooklen135, Hooklen 180, StirrupBendFormerDiam, HookBendFormerDiam, BarBendFormerDiam, PlainBar
What does this means?
Thank pro so much
