Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Modify rebar database
7 REPLIES 7
Message 2 of 8
pevelor
1456 Views, 7 Replies
Hi
I added an question to the following thread:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Custom-rebar-database/td-p/3556398
The thread was marked as solved before I added my question so I am wondering it might be overlooked.
Please take a look.
Thanks in advance.
Peder
7 REPLIES 7
Message 1 of 8
pevelor
in reply to: pevelor
Hi
I have done the above and I am able to save and continue as Patrick did.
However, I can't figure out how to get my new rebars to display in the reinforcement type box.
What should I do differently?
Message 3 of 8
Artur.Kosakowski
Try to copy the edited database to the C:\ProgramData\Autodesk\Structural\Common Data\2013\Data\Reinf
Artur Kosakowski
Message 4 of 8
pevelor
in reply to: Artur.Kosakowski
I had actually done that. I repeated the whole process and restarted my computer which worked.
Message 5 of 8
dear all
please explain for me are columns in the rebar database, in image below
thank all
Message 6 of 8
Artur.Kosakowski
Have you tried to look at the description tab of the table you opened? Smiley Happy
Artur Kosakowski
Message 7 of 8
Dear Pro
I edit rebar database from bar_SNIP 2.03.01-84. Then I want to edit it to my database.
Please explain for me formual of : Hoolen90, Hooklen135, Hooklen 180, StirrupBendFormerDiam, HookBendFormerDiam, BarBendFormerDiam, PlainBar
What does this means?
Thank pro so much
Message 8 of 8
Artur.Kosakowski
Artur Kosakowski
