I have two RC slabs monolithically cast into a 1550mm deep beam at adjacent sides but at different levels (TOS +5.300 & 4.350 respectively).
How would I model this? The beam would be modelled with it's centreline on the edge of the top slab and then offset down so that the top of the beam will sit flush with the slab (as shown below). Would I then have to use rigid links to provide a connection between the slab nodes and the beam centreline? Please could you advise how I do this?
Thank you
Richard
