bONJOUR
cOMMENT MODELISER EN 3D tablier pont en Béton armé ,portée 20 m
3 poutres espacé de 2.5 m
entretoise tous les 5 m suivant la portéé
epaisseur dalle 0.35 m
Merci infinement
In general the steps are:
1. Set your working plane as XY
2. Define the outer contour of the deck (panel) and assign it the appropriate thickness
3. Define bars representing girders and beams
OK ,thanks,
Can you give me an example with file autodesk please to understand the process and how to get solution
Best regards
can you send the answer on mntrandria@yahoo.fr please
Try to look at http://www.robotoffice.com/rsa/
