Modeling an elliptical section in Robot
9 REPLIES 9
Message 1 of 10
mpcloob
1382 Views, 9 Replies
in the name of  GOD  .
hello
how can I model an elliptical section in Robot ?
please attach an image for your answer.
very thanks beforehand. Smiley Wink
9 REPLIES 9
Message 2 of 10
Artur.Kosakowski
in reply to: mpcloob
You can create a section of an arbitrary shape using the Section Builder module of Robot. There you can either draw its shape or import it from dxf file.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Message 3 of 10
mpcloob
in reply to: Artur.Kosakowski
where is "section builder" in robot ?  please give me this path with image.
very thanks Smiley Wink
Message 4 of 10
Artur.Kosakowski
Please check: http://help.autodesk.com/cloudhelp/2015/ENU/Robot/files/GUID-7D345A3C-0AB0-4077-987D-3B1C70CC33EC.ht...
Artur Kosakowski
Message 5 of 10
mpcloob
thanks.
2 questions:
1 ) can i draw an elliptical section in "section definition" module without import dxf file ?
2 ) can i fill parameters in attached image in robot instead of draw section in "section definition" module ?
Smiley Wink
Message 6 of 10
Artur.Kosakowski
Yes, you can.
http://help.autodesk.com/view/RSAPRO/2015/ENU/?contextId=HIDD_RSEC_POLYLINE
Yes, you can. In such case you will not see the real shape of a section but the static calculations can be performed as or any other section.
Artur Kosakowski
Message 7 of 10
mpcloob
thanks.
answer 2 is ok but in answer 1 i don't know how to draw an elliptical section with certain "a" and "b" of ellipse equation ? (see image).
please draw an ellipse in "section definition" module of robot and attach for me file or image of that.
very thanks. Smiley Wink
Message 8 of 10
Artur.Kosakowski
You  need to approximate it with straight segments.
Artur Kosakowski
Message 9 of 10
mpcloob
thanks. Smiley Wink
therefore it's impossible to draw ellipse exactly. yes ?
if i draw an ellipse in autocad and convert it's format to "dxf" and import dxf file to "section definition" module, is this method the best method for draw an ellipse in robot ?
Message 10 of 10
Artur.Kosakowski
They are similar. The shape from dxf will be divided into number of straight lines too.
Artur Kosakowski
