Please see this file:
In this case i have to maintain designing at global model, otherwise i was studying simplified models.
There you can view that bracing system is defined with truss bars + tension only...when running this model it really takes a lot to do it and this is being a huge problem for me.
Can you take a look?
Thanks in advance,
RR
Solved by Rafal.Gaweda. Go to Solution.
Hint: if you do not need simple cases results just set these cases as auxiliary and calculate only combinations.
Good Morning Rafal,
Nice hint! I didn't knew that possibility. 🙂 kudo4u
If the structure remains symmetric, i will also reduce the number of cases wind to half.
Any other tips/hints?
Ty,
RR
Is there any way to see final calculation time?
Because that window that opens when i run my model, closes before i can see final calculation time.
in Calculation Note
