I have 3 warning after calculated a 3 storey RC frame:
-incoherent mesh on edges
-cohesion of the calculation model has been provided by definition of kinematic constraints in incoherent points of finite element mesh
-linear load as not been applied to a pannel
I have tryed to follow other post and change the mesh settings but it is even worse.
I have attached the model file:
http://www.filemail.com/t/36154234cbb54dc9834ae45ca2b1d2d6
thank you
Solved by Artur.Kosakowski. Go to Solution.
Solved by Rafal.Gaweda. Go to Solution.
Sorry but from the attached picture I can't understand how to define the zones and if I have even 1 warning I can't run the calculation for the provided reinforcements.
https://screencast.autodesk.com/main/details/f9b642ea-dfd8-4f1d-8acc-1e962f5984d6
Is it possible to generate reinforcement drawing for each direction? (top X, top Y, bottom X and bottom Y)
Only be editing the ones generated in Robot (e.g. in ASD Reinforcement or saved as dxf).
