Is there a way to do a model merge in Robot for two elements that are overlapping?
Solved by Artur.Kosakowski. Go to Solution.
Assuming that this is the situation as shown on the attached picture it would be enough just to change Node 2 for Bar 1 from 2 to 3 in the Bar table of graphically move node 2 to the position of node 3 (they will be automatically merged during model generation that is launched before calculations).
