is it possible to see mode shape like below (attached picture )
only on XY plane
note : i can get them in Modal Analysis Results table
thanks
Solved by Rafacascudo. Go to Solution.
Of course!! select your modal case and
Rafael Medeiros
Is that correct? 0,01Hz?
Look at the "Diagram scale for 1 (cm)" , it´s a huge number!!!
Do you get instabilities during analysis?
Maybe something is not right with your model!
Rafael Medeiros
yes you are right
this is test model and i know results are incorrect because i have created this model quickly ( just for comparison )
thanks Rafa
