First of all I apologize if this problem has bein postet before, but I could not find a result for it.
I am trying to do a modal analysis on my Bachelor's project, on which I want the results only on X&Y;
after setting everithing, I runnedd the calculations in order to see in which mode participates the most mass, and I encounter this error:
Number of missing eigenvalues found = 2
the error repeats itself in several cases before the calculations are done.
I do not know how to solve it, and I think I did the steps for modal analysis wright.
Any help or suggestions would be greatly appreciated.
With regards,
Dan,Suciu
Solved by Rafal.Gaweda. Go to Solution.
Sturm Check procedure finds missing eigenvalues.
If you do not want it to be done - turn off Sturm Check in Modal analysis.
