Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
modal analysis
3 REPLIES 3
605 Views, 3 Replies
modal analysis
in a simple 2D model, stiffness and mass given, I am trying to get the same frequency when using a) mass b) mass changed into a force, and in analysis option the convert load to mass option for the modal analysis.
The mass direction is only in the z direction, for the a) option works fine, for the b) I get wrong results
Any help?
Thank you
3 REPLIES 3
Artur.Kosakowski
1. Model type should be frame rather than truss (instability if support defined in one node only)
2. Support should be such that it restrains d.o.fs so that there is no instability
3. If you want to convert force into mass you have to define it first (case 3).
I'm attaching the corrected model.
Artur Kosakowski
so it means that, first u have to define a load case with the force - new modal analysis  and convert the force to mass of the load case with the force into the modal analysis.
Artur.Kosakowski
The order of cases is not important. The rest is as you wrote.
Artur Kosakowski
