Hi!
Question 1: I am running modal analysis in a multi-story building to do seismic analysis.
However it seems impossible to get the relative masses over 90 percent!. What is the reason for this? It seems OK in Y-direction, but not X.
Question 2: Is it preferable to add linear releases to walls and slab connections? And is this the correct way to approach it?
Solved by Rafal.Gaweda. Go to Solution.
1. Model link: http://www.filedropper.com/byggbeptest
2. What do you mean? Is this the Wrong approach? The shear walls are pinned in the bottom.
I do not know what you mean by pinned but ffff means all dofs are free (released) => bottom of the wall not connected to slab
Rafal is telling you that your walls are not connected each other, neither with the slab.
there not rease for such releases and it will create a mechanism.
the only interessting releases :
Foundation level : possibly rotation is free if you design your foundation this way
Edge of slabs : rotation is free if you decide, Rx/Ry free if you have got an expansion joint with a slidding support (watch that there is always some friction between slab and support even if it is considered fully released)
On the file you sent you have to run at least 45 modes.
