I have the following doubt, i was running a simple modal analysis on a column only with self-weght, and i noted that if i divided the column into more elements ( or just created more nodes) the frequency of column changed.
What i want to know if this discretization gives more accurate results, i.e, the mass of the column is distributed into n degree of freedom along the column?
Thank you and regards,
fmp
Solved by Artur.Kosakowski. Go to Solution.
Yes, it does especially when you use the lumped mass matrix where mass can only be 'assigned' to nodes.
