Discussion Groups
Robot Structural Analysis
Valued Contributor
bjornhgr
Missing labels in Maps on Bars
456 Views, 9 Replies
12-20-2011 06:09 AM
Hi.
I'm trying to display normal forces in cross bracings in a steel frame structure in a readable way. I want to display an elevation with normal forces and labels on each bar. trying to use the Maps on Bars function I get _some_ of them, but never all of them at once. Why is this so hard, and is there anything I can do to fix it? It's driving me nuts. I've tried zooming in and out, but there are always some forces missing...
Please use plain text.
Product Support
Rafal.Gaweda
Re: Missing labels in Maps on Bars
12-21-2011 02:17 AM in reply to: bjornhgr
What about using Labels?
HInt below:
Rafal Gaweda
Valued Contributor
bjornhgr
01-18-2012 05:09 AM in reply to: Rafal.Gaweda
Hi.
This problem was put on hold along with my project before christmas. Now I'm back at it, and the problem remains unsolved. I know about moving labels, but it doesn't help much when several bars meet (attached image). Using text I avoid this, but but it gets real messy (attached image), and it takes a lot of time cleaning it up when I have eight braces.
Is there really no solution to this? I just want the maximum value for each bar, graphically displayed for easy reading...
Distinguished Contributor
mirko.jurcevic
02-08-2013 03:03 AM in reply to: bjornhgr
Maybe this can help:
I've added additional nodes on bars and Robot displays "labels" (values) in nodes. See image attached.
My question: is there any other way to display additional values for diagrams. Let's say that Robot displays diagram value at beggining and the end of the element but I want also to see value in the middle, or at any other place. Is there a way to display additional value without adding a node at that place?
Something like when displaying maps for surface elements - there is possible to display value at specific point.
INTELIKA
Mirko Jurcevic M.Eng.
INTELIKA d.o.o.
www.intelika.hr
Product Support
Rafal.Gaweda
02-08-2013 04:08 AM in reply to: mirko.jurcevic
No. As you mentioned - add nodes.
Rafal Gaweda
mirko.jurcevic
02-08-2013 04:31 AM in reply to: Rafal.Gaweda
That's bad.
And what if I don't know in advance where I'll need to put nodes.
Process would be:
calculate model -> find places where you need additional values -> remember/write down positions of additional nodes -> add nodes -> calculate again -> find out that you missed something -> swear -> add nodes -> calculate again
And imagine what if you need half an hour for each calculation.
I don't know, there got to be an easier way to do this.
And what when I right click to diagram value text and delete it? How can I get it back?
INTELIKA
INTELIKA d.o.o.
www.intelika.hr
mirko.jurcevic
02-08-2013 04:41 AM in reply to: mirko.jurcevic
I've found out: And what when I right click to diagram value text and delete it? How can I get it back?
View -> Descriptions -> Restore Deleted Descriptions
INTELIKA
INTELIKA d.o.o.
www.intelika.hr
Product Support
Rafal.Gaweda
02-08-2013 04:51 AM in reply to: mirko.jurcevic
Use Detailed Analysis : http://screencast.com/t/uiKgsVAM0Ewd
Rafal Gaweda
mirko.jurcevic
02-08-2013 05:53 AM in reply to: Rafal.Gaweda
Thanks, that's useful! :smileyhappy:
Screen capture takes diagrams+table at the same time, which is good.
But, I don't have that vertical blue bar for reading values.
And, on my sample model, when I insert column in detailed analysis I get wrong direction of load forces.
Look at the images attached.
INTELIKA
INTELIKA d.o.o.
www.intelika.hr
Product Support
Rafal.Gaweda
02-08-2013 06:09 AM in reply to: mirko.jurcevic
Thx for reporting. I will registser it for correction.
Rafal Gaweda
