Discussion Groups
Robot Structural Analysis
New Member
ricardo_moreira
minimum reinforcement of foundation
1295 Views, 5 Replies
06-22-2011 04:34 AM
Hi everyone,
I would like to Know how what is the expression of Eurocode, that the Robot use to calculate the minimum reinforcement of the foundation.
Thank you, best regards:
Ricardo Moreira (Portugal)
Edited by
Discussion_Admin
Please use plain text.
GabrieleNovembri1027
Re: minimum reinforcement of foundation
06-23-2011 11:36 PM in reply to: ricardo_moreira
I don't know what  kind of criterion Robot uses but Eurocode 8 prescribes minimum reinforcement only for beams and not for the footings for which local ductility is not required. See attached Page.
Product Support
Jakub.Brozonowicz
06-27-2011 03:55 AM in reply to: GabrieleNovembri1027
If the results from the minimum value that the answer is as follows:
We accept that the elements are reinforced ones.
Due to the limitation of damage to fragile bent elements the condition (9.2.1.1-beams, 9.3.1.1 - boards) is always used:
AsMin = 0.26 * (fctm / fyk) * b * d
When grown fck then fctm grows too.
Also the minimum reinforcement grows with it.
Jakub Brożonowicz
New Member
ricardo_moreira
06-28-2011 06:41 AM in reply to: Jakub.Brozonowicz
Thank you,
 When we define a load in "RC_Foundation design" with nature of design the programm don't use this expression "AsMin = 0.26 * (fctm / fyk) * b * d" to calculate the minimum reinforcement. It´s possible to change it ?
Best Regards:
Ricardo Moreira
Product Support
Jakub.Brozonowicz
06-30-2011 04:49 AM in reply to: ricardo_moreira
This condition is SLS oriented one.
In case of Design load only ULS state check is done and other formulas taken as reference.
Jakub Brożonowicz
Distinguished Contributor
mirko.jurcevic
02-25-2014 06:37 AM in reply to: Jakub.Brozonowicz
I don't understand this answer, and I have similar problem.
For my spread footing, Robot calculates minimum reinforcement as 4,17cm2/m' for bottom zone, and 3,14cm'/m' for top.
According to EN 1992-1-1, this values should be calculated as:
As,min = 0.0013⋅bt⋅d = 0.0013⋅100⋅44 = 5.72 cm2
or
As,min = 0.26⋅(fctm/fyk)⋅bt⋅d = 0.26⋅0.22/50.00⋅100⋅44 = 5.03 cm2
whichever is greater.
Question is simple: Which expression Robot uses to calculate minimum reinforcement of the spread footing?
INTELIKA
Mirko Jurcevic M.Eng.
INTELIKA d.o.o.
www.intelika.hr
