Discussion Groups
Robot Structural Analysis
Valued Contributor
Jesper.Jensen
Minimum reinforcement in Reinforcent Designer
372 Views, 3 Replies
09-27-2012 10:23 PM
When using the reinforcement designer for a floor plate to CP65, the only settings I can find regarding minimum reinforcement is as displayed in the attached illustration. Is there a way to see the input settings for minimum reinforcement or can you please let me know how it works?
Could it be set up so minimum reinforcement correspond to the cracking moment for the slab?
Cheers,
Jesper
Please use plain text.
Product Support
Rafal.Gaweda
Re: Minimum reinforcement in Reinforcent Designer
09-28-2012 12:31 AM in reply to: Jesper.Jensen
No, Minimum reinforcement is given by the national code.
Rafal Gaweda
Valued Contributor
Jesper.Jensen
10-03-2012 03:54 PM in reply to: Rafal.Gaweda
Is there a way I can change the input for this setting?
Product Support
Rafal.Gaweda
10-04-2012 12:06 AM in reply to: Jesper.Jensen
No, it is hardcoded.
Rafal Gaweda
