When using the reinforcement designer for a floor plate to CP65, the only settings I can find regarding minimum reinforcement is as displayed in the attached illustration. Is there a way to see the input settings for minimum reinforcement or can you please let me know how it works?
Could it be set up so minimum reinforcement correspond to the cracking moment for the slab?
Cheers,
Jesper
Solved by Rafal.Gaweda. Go to Solution.
No, Minimum reinforcement is given by the national code.
