Minimum reinforcement in Reinforcent Designer
3 REPLIES 3
Jesper.Jensen
591 Views, 3 Replies
When using the reinforcement designer for a floor plate to CP65, the only settings I can find regarding minimum reinforcement is as displayed in the attached illustration. Is there a way to see the input settings for minimum reinforcement or can you please let me know how it works?
Could it be set up so minimum reinforcement correspond to the cracking moment for the slab?
Cheers,
Jesper
3 REPLIES 3
No, Minimum reinforcement is given by the national code.
Rafal Gaweda
Is there a way I can change the input for this setting?
No, it is hardcoded.
Rafal Gaweda
