Is there any guidance documentation available which explains the Strucural Analysis options within job preferences.
I had initially hoped for guidance on whether it was a good idea to use DSC algorithm if prompted.
But on a wider subject I would really like to learn more and full understand all of the options in the structural analysis part of job preferences: including the various options within Method of Solving the System of Equations and the 3 sub sections within Modal Analysis.
Cheers
Richard
Initial analysis should be set to automatic as other solvers like multi-threaded(faster) won´t detect all possible instability types.
check
http://help.autodesk.com/view/RSAPRO/2015/ENU/?guid=GUID-C1CA3EC7-0C8E-4E11-9BD3-38C4F12494BC
http://help.autodesk.com/view/RSAPRO/2015/ENU/?guid=GUID-55EBEFB8-2064-4033-84A8-9824AE933655
Rafael Medeiros
Robot Structural Analysis
Then you really need to check the help and search for documentation on the web for each method.
In the help, generally the main steps of the algotrithmn are presented but not in details.
For dsc, make a search with keyword "dsc" and i you understand french :
