Hi
One of my panels will not for the love of god mesh when I gererate computional model. Its a shell element.
However, when I mesh it localy it works.
I have tried to freeze the mesh and then generate computional model, but it seems to delete the mesh I have frozen.
I have also saved the panel as a substructure and meshed it in a seperate RSA session, and that works fine.
Any suggestions what to do.
Regards
Peder
Solved by Rafal.Gaweda. Go to Solution.
Hi again.
I solved it by deifining several panels instead of one big one, but I am still interested in what the reason for it is
I think this is the reason:
SO I guess spliting 24_edge(2) properly -> contour point should be on right top corner of panel 2106 solves the problem
