Hi I am tryin to model a steel tank using meshing.
I am having a problem with making meshes that join at angles to connect so they act together. No matter what I do I can not make the platee that are at angles join correctly, even when i draw the new mesh at each individual node. Please see images below of example where this has happened, along with an atached file.
Thank you for your time.
Oscar Gaunt
Are panels well connected on common edges? From first screen shot I can see they are apart.
Send us model to check.
