even if we freeze the meshing on a model , after running calculations , its seems that process of remeshing start again, which can takes a long time for large models.
so , would recommend anyway this workflow, or it would be satisfactory (no problem with results) if we ask to the software to not regenerate the meshing (after a freezing the first one) at all, and then begin the calculations.
thks
Solved by Rafal.Gaweda. Go to Solution.
It is just a progress - merging nodes on commmon egdes etc.
Do you use kinematic links?
Send us model to check.
im not sure that the hole process of meshing is reloading after freezing (it seems not....) but the point is that if , after freezing it , could the fact of not generating the model - see attachment please (which can save a lot of time ) and run calculations affect the results.
For meshing i use the option 'Automatic selection of meshing method'
thks
IN case of making anly changes in model (properites, loads, geometry) it is recommended to run calcaulations with model generation.
IN case of changing calculation parameters for existing load cases (I do not mean load to mass conversion) you can skip this step
