Hi!
In the Advansed meshing options window I can choose a mashing method and it's frequency of use. How does it work?
In the Help I found only this: You can also select the degree of method implementation for each type of mesh generation: never, rarely, or often. You can define the Forcing ratio. For example, if you select the Coons' method, define the implementation degree as often, and the forcing ratio as forced, the mesh generation algorithm forces the mesh to be created in the selected region according to Coons' method.
Denis
Rafal did you notice the description and content in the link you sent is back to front? i.e. In the "Coons" section it is all the Delauney settings.
Thanks for link, Rafal!
But what is the principle of setting function of frequency in Advansed meshing options?
And why settings of method are different in Meshing options and in Advanced meshing options in this case (watch this video, please😞 http://screencast.com/t/xuBMBZusr0?
Denis
