Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Meshing connection model
3 REPLIES 3
PatrickEC
514 Views, 3 Replies
I tried various settings and I do not seem to be able to create a good mesh for my model. I will appreciate any suggestion on how to make it work.
Here is the model: http://www.mediafire.com/?u9as9onx94bmafu
3 REPLIES 3
I have sent you the corrected model (Edit > Detailed Correct > adjust to indicated planes) by email.
Artur Kosakowski
PatrickEC
in reply to: PatrickEC
Artur, thank you for your help.
I am trying to recreate your workflow, you mentioned the following steps:
1. Redefining the supports
I changed them to linear supports and it works better now.
2. Fixing the panel #102
How did you fix it?
3. Manually merging the nodes
What is the best way to do it?
4. Edit > Detailed Correct > adjust to indicated planes
What did you use it for?
I am also confused why after I delete the mesh in the first model that you sent me and then regenerate it, the new mesh is different then the original mesh. See here: http://screencast.com/t/1rDQCr34m6
How did you fix it?
See the attached picture.
Select one of nodes you want to merge and move it over another. The model generation will merge them.
 If you set the meshing parameters as Auto then the mesh depends on the order of meshing. If you look at such meshed panels and you decide that you want to alter mesh you may run local meshing which can produce different result as mesh adapts to already meshed neighboring panels.
Artur Kosakowski
