Hello
How can i correct incorrect mesh on cylindrical element in m model? Could you please help me?
I have attached a model file.
Thank you.
Solved by Rafal.Gaweda. Go to Solution.
thank you.
if i do it i will receive a new message could you please look at attached file?
thank you.
Thank you.
when i perform an analysis a received an instability warning. Could you please help me to solve it;
i attache a file and a picture.
thank you.
Ignore it it is mathematicla instability cuased by bog difference between these elements in stiffness matrix:
Stiffness matrix diagonal elements
Min/Max after decomposition: 4.032946e+007 2.539805e+019
If you use Skyline solver this instability will disappear.
One remark concerning your model : panel 97_side(13) not connected to cladding 116 and wall 104
