Hi all
The following issue is regarding the mesh generation in a very simple structure
with the same coordinate for the existing nodes (defined for beams) and the corresponding panel edge
it jumps to points in the neighbor e.g. from 1.60 to 1.59946
1.- How to force to stay at e.g. 1.6
2.- It requires most the times a geometrical correction, because it generates a new node over the existing one
3.- Nodes are also generated outside the xy-plane
Please let me know how to fix this issue, because it is very time consuming
During verification
the duplicated load label warning is on
a.- something is wrong with, because the labeling should be automatic isn´t?
b.- changing the subnature labeling DL1 DL2... LL1, LL2..., it recognizes one time, by the next generation it is wrong again..
thank you in advance
Best regards
Marcelo
Which node is it exactly please? I can't find any node with such coordinate in the model you sent.
During verification
I have asked my colleagues from the development team to try to disable the possibility of having duplicated load labels.
I have never seen such situation . From my experience each time the duplicated labels are renamed it solves the situation once and for all.
Hi Artur
In the attached file you will see the generated nodes generated out of axis
The nodes 1985 and 2671 are an example they must have the coordinate x=11.625 and have x=11.62498
therefore the mesh is generated very fine in the neighborhod
Similar situation have the nodes in the axis x=11.625, x=21.175, x=29.175 and x=31.725
Regarding the load label please, run the model after changing the labels to see the warning
Best regards
Marcelo
The reason is the inaccuracy in the modeling. I have used the detailed correction option to the structural axes and some planes to correct that.
The labels should be corrected before running the model. If you do so no message will be displayed.
