Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
mesh density overload, some loaded panels not analysing
5 REPLIES 5
499 Views, 5 Replies
Morning All,
I'm having some curious problems with this building model:
Image 1- One of the front lift panels creates an overly dense FE mesh.
Image 2 - The stairs on the RHS (in red) is loaded but doesn't seem to be analysing.
Image 3 - When adding a roof slab above the edge beam highlighted in red, the front wall panel (in red) shows no load transfer.
I also have a "no material" warning that keeps popping up during verification which I can't get rid of.
Zipped RTD file to follow. This post only allows 3 attachments at 1 time.
Any expert advice on solving the above would be greatly appreciated!
Scott
5 REPLIES 5
rtd attachment regarding post above
Romanich
first of all run generation of computational model and after that verification.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Artur.Kosakowski
Your expert name is the detailed correction to structural axes and planes where they are not defined  (you may call it precision if you prefer)  Smiley Happy
Artur Kosakowski
in reply to: Artur.Kosakowski
Many Thanks!!! It's working great now 🙂
Out of interest, is there any Robot guide / PDF focussing on debugging any of the above errors? I don't want to be the pain in the arse on this forum coming back with similar errors when they crop up.
Artur.Kosakowski
Try to use the search box located at the top fright corer and type the key words such as e.g. incoherent mesh.
See also http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Tips-for-using-Search-in-the-Autodesk-Forums...
Artur Kosakowski
