For some reason, when I undertake 'local mesh deleting' the model has stopped deleting the nodes created on line elements. Any idea why this might be?
Andrew
Solved by Artur.Kosakowski. Go to Solution.
This happens when these nodes were actually created in the different way (e.g. bar division rather than meshing) or have some additional attributes assigned (e.g. supports).
sorry sir.
when i run my model i forgot to put wind simulation .. than i didnot found wind simulation icon ???
Hi @Anonymous
I'm not sure if I understand the situation correctly. Is it that you cannot find the way to access this option in Robot? If so try Loads > Wind Loads Simulation > Generate Wind Loads commands.
If one or more of these posts answered your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
