Discussion Groups
Robot Structural Analysis
Member
0 Kudos
Mesh+Bracket error?!
1567 Views, 2 Replies
09-27-2011 12:42 AM
I encountered today a thing that never happened in Robot. When using bracket for a beam that supports a shell slab which was meshed (lets say 0.5 m mesh size), at the end of the bracket the Fz value is very big, and this never happened in older version of robot. I checked old structures made with RSA v19 or 2010 and that issue didn't exist.
 Thanks in advance!
 regards,
 Bogdan
LE: I attached the picture for the beam without the bracket
Product Support
1,303 Kudos
Re: Mesh+Bracket error?!
09-27-2011 03:46 AM in reply to: pascal.bogdan
HI,
Turn off kinematic contrains in job preferences
Rafal Gaweda
Member
0 Kudos
09-27-2011 04:09 AM in reply to: Rafal.Gaweda
Thank you! Now it works as it should :smileywink:
