Is this mesh arrangement adequate, if not.
How would I go about refining to improve it.
Regards
Solved by byron86. Go to Solution.
Solved by Rafal.Gaweda. Go to Solution.
In case of volumtric \ solid meshing there should be at least 2 elements generated across the thinest part of model to get reasonable results
Thanks appreciate it. Additionally, with regards to the properties. I dont want to apply a thickness to the solid as I have already define my shape with the geometry. However, you can select the material type as concrete but this doesnt have an fcu value only an E value. How do u apply this.
Thanks for the quick response
Regards
For FEM analysis it is not needed.
You can not run any design for solid elements so it is not needed.
But you can see material properties in Job Preferences:
