Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Member list is incorrect
5 REPLIES 5
3389 Views, 5 Replies
Morning,
I am having the issue when performing steel design of structural piles.
When i try to calculate, there is an error ``Member list is incorrect``.
I am also unable to include any members, but the structure does analyse.
Any suggestions how to correct the error?
Steve
Tags (1)
5 REPLIES 5
andrea_pontiggia
I too have had a similar problem. I had changed a concrete pillar with a steel.
Check the following settings.
Also try resetting the design parameters of the regulations
Andrea
in reply to: andrea_pontiggia
Thanks, i have tried what you suggested by i still seem to have a problem with the model.
Will keep at it.
I am unable to select any members to verify.
Have a look at the attached photos.
Steve
Rafal.Gaweda
Either wrong material (not steel) in assinged to members or steel member types are not assigned to bars.
If it is not the case please send us  model.
Rafal Gaweda
Thanks Rafal,
I have corrected the error.
Since I exported the nodes and members from SAP2000 into Excel and then into Robot, the elements were not specified as a simple bar, column etc.
Once I specified the appropriate member type I was able to calculate in steel design.
Regards
Steve
Steven Gregan Ing Civil, MSc.
Ingeniero de Proyectos
[http://www.prdw.com/sites/default/files/prdw.jpg]
Alonso de C?rdova 5900 Piso 10, Las Condes, Santiago, Chile
CP 7560830
T: + 56 2 2694 2000 | sgregan@prdw-av.com | www.prdw.com
Correo sujeto a la renuncia de responsabilidad de PRDW. Ver en: www.prdw.com/disclaimer.html
