I defined many load combinations in RSA , how can i get the maximum load combinations that give maximum stresses on the structure ?
Solved by dimogrec. Go to Solution.
Hi
You can use the Special Filter tool.
Please find the attached file
Ok thank you but , if i defined 20 combinations , how can i get the max combination that give maximum moment ?
Same as second picture of Hoshang but for forces table, and select all the cases-combinations you want in case-combination window (see my picture1)
In forces table -> Global extemes you can see the extreme values of forces and for which combination (or load) case this value occurs. The symbol (C) after the number means that it is a combination case
See also my second picture for division points to get better results
(And to see combinations definition see combination table)
