Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
masses to loads
2 REPLIES 2
262 Views, 2 Replies
masses to loads
Hello everybody, I have a model with some added masses in the nodes (masses active in X,Y,Z directions and active for all load cases) , when I run the  "static" calculation, Robot does not consider the added masses: the reactions consider only to self-weight and applied loads. Is there a way to convert the masses in loads? I am interested to convert only the masses acting in vertical direction Z.
2 REPLIES 2
Rafal.Gaweda
Not possible to convert masses onto loads but you can use them in Body Forces load.
Rafal Gaweda
in reply to: Rafal.Gaweda
Thanks a lot!
