Hello everybody, I have a model with some added masses in the nodes (masses active in X,Y,Z directions and active for all load cases) , when I run the "static" calculation, Robot does not consider the added masses: the reactions consider only to self-weight and applied loads. Is there a way to convert the masses in loads? I am interested to convert only the masses acting in vertical direction Z.
Solved by Rafal.Gaweda. Go to Solution.
Not possible to convert masses onto loads but you can use them in Body Forces load.
