Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Mass participation
23 REPLIES 23
Message 1 of 24
2310 Views, 23 Replies
Mass participation
I have only 18% mass participating in 40 modes. Could you give me your advice
23 REPLIES 23
Message 21 of 24
t.sautierr
in reply to: Rafal.Gaweda
And actually not interest to mesh if all is connected by rigid links right?
And the diaphragm (total rigid corpse) has got only 6 degrees (3 position plus 3 angles) right?
Message 22 of 24
Rafal.Gaweda
in reply to: t.sautierr
But nodes exists and they are connected by rl
As every node dof in 3D.
Diaphragm is kind of rigid link (set of rigid links) connecting each node located on diapgragm area with master node.
So to reduce number of equations you have to decerase number of nodes in model.
Rafal Gaweda
Message 23 of 24
t.sautierr
Ok got it I think.
then If he wants to reduce the number of nodes the bes is to use a cladding for the loads and RL for the diaphragm effect.
If a pannel is used and set to diaphragm, normally there will be always mesh and the nodes unless the pannel model is set to use no EF, right?
Thx one more time ...
Message 24 of 24
Rafal.Gaweda
Not always, it depends on calcaulation model :
(My recommended settings for flexible diaphragm)
Rafal Gaweda
