Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Manual verification of concrete beam
5 REPLIES 5
Mirko.Jurcevic
436 Views, 5 Replies
I've searched everywhere but no luck.
Is it possible to do manual verification of concrete beam section in Robot?
Something like this: http://docs.autodesk.com/RSAPRO/2014/ENU/index.html?url=filesROBOT/GUID-F41BDA2A-24C0-4F83-82FE-36FF...
thanks!
If this solved your issue, please Accept it as Solution help other forum users with similar issues to find answers easily.
Mirko Jurcevic
My blog: www.engipedia.com
Try my Revit add-ins: Autodesk App Store
5 REPLIES 5
No.
Rafal Gaweda
I thought so.
That's too bad.  😞
Mirko Jurcevic
Assuming it is against bending you may create a simply supported beam with uniform load of value that produces the required value of bending moment in its middle and use the typical reinforcement option top add rebars. Then you can check the capacity diagram.
Artur Kosakowski
This could be added to the wish list .... it is quite useful during ckeckings phase when the project is under construction.
Mirko.Jurcevic
in reply to: t.sautierr
I agree.
To be honest, I was suprised that there is no such tool already in Robot.
Mirko Jurcevic
