I've searched everywhere but no luck.
Is it possible to do manual verification of concrete beam section in Robot?
Something like this: http://docs.autodesk.com/RSAPRO/2014/ENU/index.html?url=filesROBOT/GUID-F41BDA2A-24C0-4F83-82FE-36FF...
thanks!
I thought so.
That's too bad. 😞
Assuming it is against bending you may create a simply supported beam with uniform load of value that produces the required value of bending moment in its middle and use the typical reinforcement option top add rebars. Then you can check the capacity diagram.
I agree.
To be honest, I was suprised that there is no such tool already in Robot.
