Discussion Groups
Robot Structural Analysis
Active Contributor
STP_MS
Manual slab reinforcement
607 Views, 12 Replies
04-03-2013 01:44 AM
Hi all
I have two problems regarding slab reinforcement.
When I manually set provided reinforcement as I wish (The set reinforcemnt seems OK, because provided reinforcement area is larger than required reinforcement area), Robot doesn' take it into account. Calculation errors an reinforcement display are attached.
The other question is how can I manually set provided reinforcement with wire fabrics instead of reinforcement bars?
Thanks in advance.
Please use plain text.
Product Support
Rafal.Gaweda
Re: Manual slab reinforcement
04-03-2013 02:19 AM in reply to: STP_MS
File please.
Rafal Gaweda
Active Contributor
STP_MS
04-03-2013 02:54 AM in reply to: Rafal.Gaweda
Product Support
Rafal.Gaweda
04-03-2013 06:25 AM in reply to: STP_MS
I guess you have frozen reinforcement before dleting it.
Rafal Gaweda
Active Contributor
STP_MS
04-03-2013 06:35 AM in reply to: Rafal.Gaweda
You're right. Thank you.
Active Contributor
85778RSAPRO_2012_0F
05-24-2013 02:49 AM in reply to: STP_MS
How can I know that reinforcement are frozen?
Waleed Khalid
Product Support
Rafal.Gaweda
05-24-2013 04:53 AM in reply to: 85778RSAPRO_2012_0F
Rafal Gaweda
matthew-spink
09-18-2014 03:34 AM in reply to: Rafal.Gaweda
Hi Rafal,
Similar to what's been discussed in this thread, I've manually drawn the reinforcement on a slab. However I can't get it to appear in the 'Slab -reinforcement' module or the Final Drawings; they both show the slab without reinforcement.
On previous slabs when I have automatically calculated the reinforcement in the provided reinforcement module then the reinforcement shows in the Final Drawings and the 'Slab - reinforcement' modules once its been calculated...
I have frozen the reinforcement, possibly before I pressed the calculate button, so my questions are: is this the reason that it isn't working? And if so how do I unfreeze the reinforcment? In the Results menu it only has freeze reinforcement, not unfreeze and freezing it twice doesn't seem to unfreeze it.
Matt
matthew-spink
09-18-2014 03:39 AM in reply to: matthew-spink
I should also add that I don't appear to have the reinforcement freeze icon/button in the toolbar as you show in message 7. But it says in the Calculation errors list and the Slab-reinforcement module as in message 4 that the reinforcement is frozen
Product Support
Rafal.Gaweda
09-18-2014 04:11 AM in reply to: matthew-spink
File please.
Rafal Gaweda
