Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Manual Increase of Iy
1 REPLY 1
AJA14
184 Views, 1 Reply
I am performaing analysis and design of a composite slab. I am approaching this with user defined beams having same properties except a higher Iy and a flexible diaphragm slab.
1- Is my approach correct or is there a better and more reliable method.
2- Shouldn't there be other parameters than Iy that need to be increased or changed. See attached image.
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
1 REPLY 1
Rafal.Gaweda
in reply to: AJA14
http://docs.autodesk.com/RSA/2013/ENU/filesROBOT/GUID-BBDCC532-E4F1-4386-9DFA-FE2EC05B44C2.htm
If you want to check stresses - set proper V... values
Rafal Gaweda
