Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
manual combination is off ????
13 REPLIES 13
Message 1 of 14
Leader_Mohamed
993 Views, 13 Replies
I have installed SP3 for RSAP 2014 and I still can't use manual combination in RC element design module Smiley Sad
Is there any way to add manual combinations because automatic combinations aren't compitable with design code of our country.
13 REPLIES 13
Message 2 of 14
Have you defined them in the model?
Artur Kosakowski
Message 3 of 14
I'm asking how can I define manual combinations ? they are define automatically !
Message 4 of 14
Download RSA 2014 SP3
Muhannad M.Abu Abdo
Structural Design Engineer
Message 5 of 14
I've already installed SP3
I tested this problem on another computer and I've found the same problem
I'll attach a file and you can see by yourself  manual combination is off
Message 6 of 14
Where is the combination in your model .. you just add loads as dead and live and don't made the combinations
Muhannad M.Abu Abdo
Message 7 of 14
Look at this ..
Muhannad M.Abu Abdo
Message 8 of 14
Show me the steps for manual combination please
I am confused
Message 9 of 14
I suggest to open frame 3d and enter the dimensions , then draw beams and apply loads then make manual combinations as you want .. finally select the beam and go to Rc beam design ... manual combinations will work correctly
Muhannad M.Abu Abdo
Message 10 of 14
why the SP3 don't solve this problem ! Smiley Frustrated
Message 11 of 14
there's no manual combinations in the RC DESIGN .. analyze the beam in frame 2d ot 3d and then take it to design .. it's work
Muhannad M.Abu Abdo
Message 12 of 14
Try like this.
If this solved your issue, please Accept it as Solution help other forum users with similar issues to find answers easily.
Mirko Jurcevic
My blog: www.engipedia.com
Try my Revit add-ins: Autodesk App Store
Message 13 of 14
Thx Mirko this is so helpful.
Message 14 of 14
Thx you mohand
