I have installed SP3 for RSAP 2014 and I still can't use manual combination in RC element design module
Is there any way to add manual combinations because automatic combinations aren't compitable with design code of our country.
Solved by Mirko.Jurcevic. Go to Solution.
Solved by MUHANNAD.ABU_ABDO. Go to Solution.
I'm asking how can I define manual combinations ? they are define automatically !
I've already installed SP3
I tested this problem on another computer and I've found the same problem
I'll attach a file and you can see by yourself manual combination is off
Where is the combination in your model .. you just add loads as dead and live and don't made the combinations
I suggest to open frame 3d and enter the dimensions , then draw beams and apply loads then make manual combinations as you want .. finally select the beam and go to Rc beam design ... manual combinations will work correctly
Try like this.
