Discussion Groups
Robot Structural Analysis
Distinguished Contributor
35 Kudos
Log of analysis errors?
295 Views, 1 Replies
06-18-2012 01:28 PM
I get Type 3 instability error which I know I can ignore and because I run non-linear analysis I have to click Escape to ignore these errors, because otherwise it would pop up at each iteration. Consequently, I do not see other  potential error messages. Are analysis errors logged somewhere? (I know that for example I can figure out any convergence problems from the calculation note.)
Valued Mentor
182 Kudos
Re: Log of analysis errors?
06-18-2012 04:18 PM in reply to: PatrickEC
LOOK AT THE FILE "ROBWIN"
"C:\Users\XXXXXXXX\AppData\Roaming\Autodesk\Autodesk Robot Structural Analysis 2012\Tmp\robwin.log
Alternative;
Run the model using "Calculation Manager"
Start Menu ----------->Autodesk---------->RSA--------->Other Programs----------->Calculation Manager.
Set "ignore warnings" and "display note".  This will force the calc to run and will report errors.
Tony
