Discussion Groups
Robot Structural Analysis
70 Kudos
Loads diplay
148 Views, 2 Replies
01-09-2013 08:26 AM
Is there anyway to avoid this type of loads display ( beside using uniform planr contour ) ?
Thank you
Product Support
1,305 Kudos
Re: Loads diplay
01-10-2013 12:15 AM in reply to: faisal.aaouatif
It is like that if you use any 3dloads
So in case of contour loads please do not use Automatic Panel Selection...
Rafal Gaweda
Product Support
1,305 Kudos
Re: Loads diplay (API)
01-10-2013 12:54 AM in reply to: Rafal.Gaweda
In case of having linear 2p loads in model you may convert them onto linear loads on egdes using attached macro.
(if this 2p load is not defined on real panel edge please remesh panel(s) after conversion)
Rafal Gaweda
